foutcodes. cilinder enz.
sanderkors
Type auto: golf 5 gti
Bericht door sanderkors »
Gister reed ik met me golf 5 gti en was ik in 1 keer me vermogen kwijt toen ben ik gaat kijken was het slangentje (intake manifold gas outlet eraf geschoten en nu lees ik deze fout codes uit de auto. wat zou het probleem kunnen zijn?
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1K0 907 115 Q HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWX7Z0GN3NK9EA
Coding: 0403000318070160
Shop #: WSC 01279 785 00200
VCID: 346D6D74572070E
9 Faults Found:
001056 - Catalyst System; Bank 1
P0420 - 002 - Efficiency Below Threshold - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 2
Fault Frequency: 1
Mileage: 80152 km
Time Indication: 0
Date: 2000.00.00
Time: 06:03:51
Freeze Frame:
RPM: 1950 /min
Load: 34.1 %
Speed: 79.0 km/h
Temperature: 80.0°C
Temperature: 9.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 14.478 V
P2177 - 001 -
Freeze Frame:
Fault Status: 01100001
Fault Priority: 2
Fault Frequency: 2
Mileage: 82197 km
Time Indication: 0
Date: 2000.00.00
Time: 00:39:26
Freeze Frame:
RPM: 2912 /min
Load: 19.2 %
Speed: 99.0 km/h
Temperature: 75.0°C
Temperature: 26.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.478 V
004243 - Bank 1; Fuel Measuring System 2
P1093 - 008 - Malfunction - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Mileage: 82464 km
Time Indication: 0
Date: 2000.00.00
Time: 20:51:35
Freeze Frame:
RPM: 3406 /min
Load: 12.5 %
Speed: 117.0 km/h
Temperature: 74.0°C
Temperature: 24.0°C
Voltage: 14.351 V
008801 - Boost Pressure Control Valve (N249)
P2261 - 008 - Mechanical Malfunction - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 82464 km
Time Indication: 0
Date: 2000.00.00
Time: 20:51:36
Freeze Frame:
RPM: 3016 /min
Load: 12.5 %
Speed: 114.0 km/h
Temperature: 74.0°C
Temperature: 24.0°C
Voltage: 14.478 V
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 002 - - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Mileage: 82470 km
Time Indication: 0
Date: 2000.00.00
Time: 20:56:02
Freeze Frame:
RPM: 2279 /min
Load: 27.0 %
Speed: 75.0 km/h
Temperature: 76.0°C
Temperature: 28.0°C
Voltage: 14.351 V
000769 - Cylinder 1
P0301 - 002 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 82471 km
Time Indication: 0
Date: 2000.00.00
Time: 20:56:45
Freeze Frame:
RPM: 2972 /min
Load: 63.9 %
Speed: 26.0 km/h
Temperature: 75.0°C
Temperature: 27.0°C
Voltage: 14.351 V
000771 - Cylinder 3
P0303 - 002 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 82471 km
Time Indication: 0
Date: 2000.00.00
Time: 20:56:45
Freeze Frame:
RPM: 2972 /min
Load: 63.9 %
Speed: 26.0 km/h
Temperature: 75.0°C
Temperature: 27.0°C
Voltage: 14.351 V
000772 - Cylinder 4
P0304 - 002 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 82471 km
Time Indication: 0
Date: 2000.00.00
Time: 20:56:45
Freeze Frame:
RPM: 2972 /min
Load: 63.9 %
Speed: 26.0 km/h
Temperature: 75.0°C
Temperature: 27.0°C
Voltage: 14.351 V
000770 - Cylinder 2
P0302 - 002 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 82471 km
Time Indication: 0
Date: 2000.00.00
Time: 20:56:45
Freeze Frame:
RPM: 2972 /min
Load: 63.9 %
Speed: 26.0 km/h
Temperature: 75.0°C
Temperature: 27.0°C
Voltage: 14.351 V
Readiness: 0000 0000
Je eigen vag-com kabel 11.11.3 voor 40 euro Stuur een pb.
Terug naar “VAG-COM”
