MOTUL DOT 5.1 REMOLIE
Dry boiling point: 270 °C
Wet boiling point: 185 °C
100% synthetic brake fluid on polyglycol basis for all types of hydraulic actuated brake and clutch systems in accordance with DOT 5.1, DOT 4 and DOT 3 manufacturers’ recommendations.
Specially designed for anti-locking brake system (ABS).
Standards: FMVSS 116 DOT 5.1 NON SILICONE BASE & DOT 4 & DOT 3; SAE J 1703.
Prijs per 0.5L
Bestellink: http://www.fineline-imports.nl/onderhou ... 52735.html
FERODO DOT 5.1 REMOLIE
Ferodo DOT 5.1 is particularly suitable for vehicles equipped with ABS braking systems because of the short cycle time required.
Also a natural choice for high performance and racing cars where the exceptionally high boiling point gives maximum resistance to vapour lock.
It avoids the spongy brake pedal, air solubility and water incompatibility associated with silicone based DOT 5 fluids.
Extremely high 260 C boiling point, which is retained better than DOT 4
Ideal for ABS
Very low - 55 C freezing point
Prijs per 0.5L
Bestellink: http://www.fineline-imports.nl/remmen-r ... 12142.html
MOTUL RBF 600 FACTORY REM OLIE
Dry boiling point : 312°C
Wet boiling Point: 205°C
Very high performance brake fluid for hydraulic brakes and clutches.
100% synthetic
Polyglycol-based brake fluid exclusively designed for racing
Resist high temperatures and wet-weather conditions
FMVSS 116 DOT 4, SAE J1703, ISO 4925
500ml Bottle
Bestellink: http://www.fineline-imports.nl/onderhou ... 52736.html
MOTUL RBF 660 FACTORY BRAKE FLUID
Dry Boiling Point: 325 °C
Wet Boiling Point: 205 °C
Motul RBF 660 far exceeds DOT 3 and DOT 4 specifications. Extremely high wet and dry boiling points (dry boiling point even higher than Motul RBF 600) help prevent vapor lock and fade in the harshest environments. Bottles are filled with nitrogen to extend shelf life and eliminate contamination while factory sealed. Suitable for any vehicle requiring DOT 3 or DOT 4 fluid.
Application: Brake Fluid 0.5 liter
Quality: 100% Synthetic
Product Range: Car and Motorcycle
OEM Approvals: FMVSS 116 DOT 4, SAE J1703
Bestellink: http://www.fineline-imports.nl/onderhou ... 52737.html
Remolie Motul en Ferodo
- Fine Line Imports
- Type auto: Subaru Impreza
Website: https://www.fineline-imports.nl
Facebook: https://www.facebook.com/FineLineImportsnl/
email: info@fineline-imports.nl
Wij zijn van 09.00 tot 15.00 te bereiken op 036-8447700 of 06-24666645
leverancier van o.a. Ferodo, Brembo, DBA, Whiteline, GFB, Hawk, Invidia, Supersprint, Xforce, Turbosmart, ACL en nog veel meer
Gebruikers op dit forum: Geen geregistreerde gebruikers en 94 gasten
